dell studio xps m1330 wistron thurman discrete vga nvidia g86 schematic
dell studio xps m1330=1=wistron thurman discrete vga nvidia g86.pdf
This Wistron-manufactured Dell Thurman Discrete motherboard (Project Code 91.4C301.001, PCB P/N 0624735, Revision -1 / DELL A00) is built around the Intel Mobile CPU Merom 4M with FSB 667/800 MHz and the Intel ICH8-M southbridge. Graphics are handled by an nVidia nB8M discrete GPU based on the G86 architecture. The system uses two 200-pin DDR2 SODIMM sockets supporting DDRII 533/667 MHz memory. The embedded controller is an SMSC MEC5025, which is programmable. The BIOS is stored on a 16Mb SPI flash. Power management is handled by a combination of ICs including TPS51120, TPS51124, ISL6260C, TPS51117, and TPS51100, with battery charging managed by a MAX8731. Audio is provided by a STAC 9228 codec, networking by a BCM5906 LAN IC, and card reading by a Ricoh R5C833 controller. Thermal monitoring is performed by an EMC4001 sensor.
Q: What is the exact EC/KBC model used on this motherboard?
A: The embedded controller is an SMSC MEC5025.
A: Yes, the SMSC MEC5025 EC is programmable.
A: The BIOS is stored on a 16Mb SPI flash.
Q: What is the charging IC used on this motherboard?
A: The battery charger IC is a MAX8731.
| Brand | Dell |
| Model | Thurman Discrete |
| Project Code | 91.4C301.001 |
| Board Number | 0624735 |
| Revision | -1 (DELL:A00) |
| Date | Tuesday, November 06, 2007 |
| CPU Platform | Intel Mobile CPU Merom 4M FSB:667/800 Mhz |
| PCH / Southbridge | Intel ICH8-M |
| GPU Type | nVidia nB8M |
| Graphics Architecture | nVidia G86 |
| EC / KBC | SMSC MEC5025 |
| EC/KBC Programmable | Yes |
| Audio Codec | STAC 9228 |
| BIOS / SPI Flash | SPI FLASH 16Mb |
| Charging IC | MAX8731 |
| Power IC(s) | TPS51120, TPS51124, ISL6260C, TPS51117, TPS51100 |
| RAM Type | DDRII 533/667MHz |
| RAM Architecture | 200-PIN DDR2 SODIMM |
| Card Reader IC | Ricoh R5C833 |
| LAN IC | BCM5906 |
| WiFi / WLAN IC | MAX4401A |
| Thermal Sensor | EMC4001 |
91.4C301.001
0624735
800 MHZ
Merom
ICH8
NB8M
nVidia G86
MEC5025
STAC9228
MAX8731
ISL6260C
TPS51100
TPS51117
TPS51120
TPS51124
RICOH R5C833
BCM5906
MAX4401A
EMC4001
91.4C301.001
0624735
800 MHZ
Merom
ICH8
NB8M
nVidia G86
MEC5025
STAC9228
MAX8731
ISL6260C
TPS51100
TPS51117
TPS51120
TPS51124
RICOH R5C833
BCM5906
MAX4401A
EMC4001
