File Request dell latitude 7320
CZ027
Hany
dell latitude 7320
hi, can you fix this bios dump the problem is dont see the hard disk its M2. thanks
i have tray all the files wat you have en web and not working same problem
  • clearmes ok .bin
CZ027
Hany
same problem just color on screen red, green and white i have try this file befor please fix de copy what i send.
i wil send onother file if you can remove the MDM SECURITY OF IT PLEASE ITS FOR THE SAME MODEL
  • MDM SECURITY.BIN
Go to Settings, then Security, then Device Administrator and disable it. Then, go to Applications, select ManageEngine Mobile Device Manager Plus, and uninstall it. Disable the Company Portal app Sign in to the Company Portal, tap the main menu, tap Remove Company Portal, and tap OK
CZ027
Hany
can you fix the first bios copy please to let the bios see the hdd or send a working bios file . thanks
