Dell E5250 LA-A891P HOUSTON 12 UMA DOCK 10L Rev 10 HSW X-BUILD GERBER BOM 0804 Schematic
| Brand | Dell |
| Model | Houston 12" UMA Dock M/B |
| Motherboard Manufacturer | Compal |
| Board Number | LA-A891P |
| Revision | 1.0 (A00) |
| Date | 2014-08-04 |
| CPU Platform | Broadwell U Processor |
| EC / KBC | SMSC KBC MEC5085 |
| Audio Codec | ALC3235 |
| BIOS / SPI Flash | W25Q32BVSSIQ / W25Q64CVSSIQ |
| BIOS Flash Exact Model | W25Q32BVSSIQ |
| BIOS Flash Capacity | 64M 4K sector / 32M 4K sector |
| LAN IC | Intel Clarkville I218L |
| Card Reader IC | O2 Micro OZ777FJ2LN-B |
| RAM Type | DDR3L |
| RAM Architecture | DDR3L-DIMM |
| RAM Quantity / Slots | BANK 0, 1, 2, 3 / BANK 0, 1, 2, 4 |
| WiFi / WLAN IC | WLAN/BT/ |
| HDMI Level Shifter | Parade PS8339 / Parade PS8338 |
| USB Hub IC | PI3USB3102ZLEX / NX3DV221GM |
| Charging IC | TPS2544 |
| Charger Architecture | USB POWER SHARE |
| Power IC(s) | Automatic Power Switch (APS) |
| Thermal Sensor | Free Fall sensor |
| TPM | Discrete TPM AT97SC3205 |
| Smart Card Controller | TDA8034HN |
| NFC Controller | BCM20793 |
| Fingerprint Controller | FP_USB Fingerprint CONN |
| SATA Re-Driver | PERICOM (SA00004H100) (UN2) |
| USB Power Switch | TPS2544 |
| USB Hub IC | IDT VMM3320 |
| eDP | Trough eDP Cable |
| mDP | mDP CONN |
| HDMI | HDMI CONN |
| VGA | VGA |
| Docking Connector | DOCKING CONN |
| SD Card | SD4.0 |
| Smart Card Reader | USH board BCM5882 |
| WWAN | WWAN/LTE/HCA |
| WIGIG | WIGIG |
| FAN | FAN CONN |
| LED | On LED/BLP |
| LID Switch | LID switch |
| Digital MIC | Dig. MIC |
| Internal Speaker | INT. Speaker |
| Combo Jack | Combo Jack |
LA-A891P
Broadwell-U
MEC5085
ALC3235
W25Q32BVSSIQ
W25Q64CVSSIQ
CLARKVILLE I218L
O2 MICRO OZ777FJ2LN-B
DDR3L
PS8338
PS8339
NX3DV221GM
PI3USB3102ZLEX
TPS2544
DISCRETE TPM AT97SC3205
TDA8034HN
VMM3320
LA-A891P
Broadwell-U
MEC5085
ALC3235
W25Q32BVSSIQ
W25Q64CVSSIQ
CLARKVILLE I218L
DDR3L
PS8338
PS8339
NX3DV221GM
PI3USB3102ZLEX
TPS2544
TDA8034HN
VMM3320
