Dell D7 SFF3 Rev X02 Schematic
The Foxconn D7X02 motherboard is an Intel SkyLake platform design dated July 27, 2015. The audio subsystem is handled by an ALC3234 codec, while networking is provided by a Realtek RTL8111HSD LAN IC and an Intel Jacksonville WiFi/WLAN module. Power management is complex, utilizing multiple regulators including AOZ2236QI-02, AOZ2238QI-02, NCP81203MNTXG, NCP81166MNTBG3, RT8237EZQW, RT6575BGQW, AZ34063UMTR-G1, APL5325BI-TRG, NCP51200MNTXG, and AP22802AW5-7. The charging architecture is USB-based, controlled by a PI5USB2546AZHEX IC. Memory configuration supports four DDR4 slots arranged as CHA0 DIMM3, CHA1 DIMM1, CHB0 DIMM4, and CHB1 DIMM2. The board also integrates an HDMI level shifter identified as HDMI-15121404632.
Q: What is the drawing number for this motherboard?
A: The drawing number is D7X02.
Q: What CPU platform does this motherboard support?
A: This motherboard supports the Intel SkyLake platform.
A: The audio codec is ALC3234.
A: The LAN IC is Realtek RTL8111HSD.
A: The memory architecture consists of four DDR4 slots: CHA0 DIMM3, CHA1 DIMM1, CHB0 DIMM4, and CHB1 DIMM2.
| Brand | Foxconn |
| Motherboard Manufacturer | Foxconn |
| Drawing Number | D7X02 |
| Date | Monday, July 27, 2015 |
| CPU Platform | Intel SkyLake |
| Audio Codec | ALC3234 |
| LAN IC | RTL8111HSD |
| Charging IC | PI5USB2546AZHEX |
| Charger Architecture | USB Charging |
| RAM Architecture | DDR4 CHA0 DIMM3, DDR4 CHA1 DIMM1, DDR4 CHB0 DIMM4, DDR4 CHB1 DIMM2 |
| RAM Quantity / Slots | 4 |
| Power IC(s) | AOZ2236QI-02, AOZ2238QI-02, NCP81203MNTXG, NCP81166MNTBG3, RT8237EZQW, RT6575BGQW, AZ34063UMTR-G1, APL5325BI-TRG, NCP51200MNTXG, AP22802AW5-7 |
| USB Hub IC | PI5USB2546AZHEX |
| WiFi / WLAN IC | Intel Jacksonville |
| HDMI Level Shifter | HDMI-15121404632 |
Skylake
ALC3234
RTL8111HSD
PI5USB2546AZHEX
AOZ2236QI-02
AOZ2238QI-02
AP22802AW5-7
APL5325BI-TRG
AZ34063UMTR-G1
NCP51200MNTXG
NCP81166MNTBG3
NCP81203MNTXG
RT6575BGQW
RT8237EZQW
PI5USB2546AZHEX
HDMI-15121404632
Skylake
ALC3234
RTL8111HSD
PI5USB2546AZHEX
AOZ2236QI-02
AOZ2238QI-02
AP22802AW5-7
APL5325BI-TRG
AZ34063UMTR-G1
NCP51200MNTXG
NCP81166MNTBG3
NCP81203MNTXG
RT6575BGQW
RT8237EZQW
PI5USB2546AZHEX
HDMI-15121404632
