Schematic dell 03485-sc molokai tvbd x01 schematic
dell 03485-sc molokai tvbd x01 1
BrandWistron Corporation
Motherboard ManufacturerWistron Corporation
Board Number03485-SC
RevisionX01
DateThursday, February 26, 2004
PCB P/N03485-SC
Project CodeMOLOKAI TV Board
Document NumberCRMA_1
This Wistron Corporation MOLOKAI TV Board, PCB P/N 03485-SC, revision X01, dated Thursday, February 26, 2004, is a dedicated TV output board designed for integration into a larger motherboard system. The board features a TVOUT connector, an RJ45 LAN connector, and a DC jack, with integrated LAN/MODEM connectivity via an adapter into the mainboard connector. It includes ESD protection diodes, a 6 MHz low-pass filter, and LED indicators for TX/RX activity and link speeds of 10 and 100. The board is identified under document number CRMA_1.
Q: What is the PCB part number for this board?
A: The PCB part number is 03485-SC.
Q: What is the revision of this board?
A: The board revision is X01.
Q: What is the project code for this board?
A: The project code is MOLOKAI TV Board.
  • Dell=1=03485-SC_MOLOKAI_TVBD_X01.pdf
