Schematic compal la-1371 acl05 rev 1.0 schematic
BrandCompal
ModelLA-1371
Document NumberACL05 LA-1371 Schematics
RevisionREV 1.0
Date星期一 07, 2003 四月
CPU PlatformINTEL Coppermine-T or Tualatin CPU uFCBGA/uFCPGA
PCH / SouthbridgeICH3-M
GPU TypeAlmador-M([URL="https://dr-bios.com/components/graphics-models/830mg/"]830MG) + VCH Chipset[/URL]
EC / KBCNS PC87591
Audio CodecCS4299
BIOS / SPI FlashEEPROM(24C16/02)
Charging ICOZ163
RAM TypeSDRAM
RAM Quantity / SlotsSO-DIMM * 2
Thermal SensorMAX1617MEE
Card Reader ICPCI1420
USB Hub ICICS9250-38
LAN ICRTL8100-L
WiFi / WLAN ICMini PCI Socket
Super I/OLPC47N227
Clock GeneratorICS9238-50
IEEE 1394 ControllerTI TSB43AB22
Audio AmplifierAudio Amplifier
This Compal LA-1371 motherboard schematic, revision REV 1.0, documents a platform built around the Intel Coppermine-T or Tualatin CPU in uFCBGA/uFCPGA packaging, paired with the Almador-M (830MG) GMCH and ICH3-M southbridge. The system uses SDRAM memory across two SO-DIMM slots. Embedded controller functions are handled by an NS PC87591. The BIOS is stored in an EEPROM (24C16/02). Audio is managed by a CS4299 AC'97 codec with a dedicated audio amplifier. Networking is provided by a Realtek RTL8100-L LAN controller, and wireless connectivity is supported via a Mini PCI socket. The charging circuit uses an OZ163 charger IC. Additional onboard controllers include a TI TSB43AB22 IEEE 1394 controller, a PCI1420 card reader, an ICS9250-38 USB hub, and an ICS9238-50 clock generator. Thermal monitoring is performed by a MAX1617MEE sensor, and the Super I/O is an LPC47N227.
A: The embedded controller is an NS PC87591.
A: The BIOS is stored in an EEPROM (24C16/02).
A: The charging IC is an OZ163.
A: The audio codec is a CS4299.
  • Compal=LA-1371_ACL05_Rev_1.0_DR-BIOS.COM.zip
