Schematic Clevo NH55RZQ-6-71-NH5G0-D020709 20190709 Schematic
BrandNH55RZQ
EC / KBCITE IT5570
EC/KBC PackageITE IT55701
RAM TypeDDR4 SO-DIMM
RAM ArchitectureCHA SO-DIMM, CHB SO-DIMM
RAM Quantity / Slots2
Card Reader ICRTL8411B
LAN ICRTL8411B
Audio CodecAudio Codec
WiFi / WLAN ICM.2 WLAN+BT
Charger ArchitectureAC_In, Charger
GPU TypeVGA
Graphics ArchitectureVGA PCI-E Interface, VGA Frame Buffer Interface, VGA Frame Buffer A, VGA I/O, VGA NVVDD Coupling
dGPU Chip NumberNVVDD, FBVDDQ, PEX_VDD
PCH / SouthbridgePCH
CPU PlatformProcessor
HDMI Level ShifterHDMI
USB Hub ICUSB Conn., USB Charger
Power IC(s)VDD3, VDD5, 5V, 5VS, 3.3V, 3.3VS, VDD1.05V, VCCIO, DDR 1.2V / 0.6VS, 2.5V, VCC_Core, VCCGT, VCCSA, 1.05DX_VCCSTG/VCCSFR_OC
Charging ICAC_In, Charger
Thermal SensorNVVDD, FBVDDQ, PEX_VDD
The NH55RZQ motherboard is built around an Intel processor and PCH architecture, supporting DDR4 SO-DIMM memory across two channels (CHA and CHB). The system is controlled by an ITE IT5570 EC/KBC, with the IT55701 package variant noted. Graphics are handled by a discrete VGA solution with dedicated frame buffer interfaces, NVVDD, FBVDDQ, and PEX_VDD power stages. The board integrates an RTL8411B combo card reader and LAN controller, alongside an M.2 WLAN+BT module. Power management includes a dedicated AC_In charger section and multiple regulated rails including VDD3, VDD5, 5V, 5VS, 3.3V, 3.3VS, VDD1.05V, VCCIO, DDR 1.2V/0.6VS, 2.5V, VCC_Core, VCCGT, VCCSA, and 1.05DX_VCCSTG/VCCSFR_OC. The schematic diagrams are based on version 6-7P-NH5E6-002.
A: The motherboard uses an ITE IT5570 EC/KBC, with the package variant identified as IT55701.
A: The board supports DDR4 SO-DIMM memory across two channels, CHA SO-DIMM and CHB SO-DIMM.
Q: What is the card reader and LAN controller on this board?
A: The board integrates an RTL8411B controller that handles both the card reader and LAN functions.
Q: What graphics architecture is present on this motherboard?
A: The board features a discrete VGA graphics solution with dedicated VGA PCI-E interface, VGA frame buffer interface, VGA frame buffer A, VGA I/O, and NVVDD coupling stages.
  • Clevo NH55RZQ-6-71-NH5G0-D020709 20190709.zip
