clevo n950tp6 n957tp6 6-7p-n9505-001 6-71-n9500-d01a
The N950TP6 / N957TP6 motherboard, based on schematic version 6-7P-N9505-001, is built around a processor and PCH architecture with a discrete GPU. The system memory configuration consists of two DDR4 SO-DIMM slots, designated CHA SO-DIMM_0 and CHB SO-DIMM_0. The embedded controller is an ITE IT8587 KBC. Audio processing is handled by a Realtek ALC269 VC2 codec. Networking and card reader functions are integrated into a single Realtek RTL8411B controller. USB connectivity is managed by an ASM2142 USB hub IC. The HDMI interface utilizes a PS8460 level shifter for signal conditioning.
A: The motherboard uses an ITE IT8587 KBC.
A: The audio codec is a Realtek ALC269 VC2.
Q: What is the memory configuration of this motherboard?
A: The motherboard supports DDR4 SO-DIMM memory with two slots, configured as CHA SO-DIMM_0 and CHB SO-DIMM_0.
Q: What LAN and card reader IC is used?
A: A single Realtek RTL8411B IC handles both LAN and card reader functions.
| Brand | N950TP6 / N957TP6 |
| Motherboard Manufacturer | N950TP6 / N957TP6 |
| Board Number | 6-7P-N9505-001 |
| EC / KBC | ITE IT8587 |
| Audio Codec | ALC269 VC2 |
| LAN IC | RTL8411B |
| Card Reader IC | RTL8411B |
| RAM Type | DDR4 SO-DIMM |
| RAM Architecture | CHA SO-DIMM_0, CHB SO-DIMM_0 |
| USB Hub IC | ASM2142 |
| HDMI Level Shifter | PS8460 |
