I cannot thank you enough! It's perfect>
There is one small issue, the touch screen will not function now and is not detected, I've checked all the voltages on the ribbon cable and all is correct. Is there a BIOS setting that needs to be addressed to correct this please?
do reset default bios settingsThere is one small issue, the touch screen will not function now and is not detected, I've checked all the voltages on the ribbon cable and all is correct. Is there a BIOS setting that needs to be addressed to correct this please?
I have performed a bios reset to default settings and saved the change, the touchscreen is still not recogniseddo reset default bios settings
this problem can't be solved with new bios fileI have performed a bios reset to default settings and saved the change, the touchscreen is still not recognised
DianneW , Vahab Hemmati , Salimeh Bolboli , sonyujun , ndher , aidhan01 , muhammad farooq
