apple iphone 5 n41 single brd evt3_051-9113 820-3141_rev11.0.0 schematic
iphone 5 schematic.pdf
iphone5_pcb_layout.pdf
This Foxconn motherboard is identified as the ZenVo EVT3 MLB, with a PCB document prepared on 20120503. The board is classified as a Foxconn iDPBG Confidential design, designated as a Do Not Print placement drawing for engineering validation testing at the EVT3 stage.
Q: What is the project code for this motherboard?
A: The project code is ZenVo EVT3.
Q: What is the board type and document classification?
A: The board is an MLB (Main Logic Board) with a PCB placement drawing, classified as Foxconn iDPBG Confidential Do Not Print.
This Foxconn iDPBG ZenVo EVT3 MLB placement drawing, dated 20120503, provides the PCB layout reference for this motherboard. The document is marked as confidential and is designated as a Do Not Print placement drawing, indicating its engineering-stage nature for the EVT3 prototype phase.
Q: What is the board number for this motherboard?
A: The board is identified as the ZenVo EVT3 MLB.
Q: Who manufactured this motherboard?
A: The motherboard was manufactured by Foxconn iDPBG.
Q: What is the date of this schematic?
A: The schematic is dated 20120503.
| Brand | Foxconn |
| Project Code | ZenVo EVT3 |
| Board Number | MLB |
| Date | 20120503 |
| Document Number | PCB |
| Motherboard Manufacturer | Foxconn iDPBG |
| Date | 20120503 |
