acer quanta zg1-mb-0226 rev-2a 1
The Quanta Computer ZG1S motherboard, project code ZG1S, revision A3, dated 2003,5,29, is built around the Micro-FCPGA CPU platform supporting BANIAS/ODEM processors paired with an ICH4-M southbridge. Graphics are handled by an ATI M7/M9 video controller. The system uses DDR SDRAM memory across two DDR-SODIMM slots. The embedded controller is a PC87591, and the audio codec is a TI-TPA43AB21. Charging is managed by a MICREL 280 IC. Networking includes a 4401/5702 LAN IC and Mini-PCI WiFi support. The card reader is an O2 OZ711M1, and a CK408 USB hub IC is present. A dedicated CPU thermal sensor is included for temperature monitoring.
A: The board number is ZG1, and the project code is ZG1S.
A: The EC/KBC is a PC87591.
A: This motherboard supports DDR SDRAM in two DDR-SODIMM slots.
A: The charging IC is a MICREL 280.
| Brand | Quanta Computer |
| Model | ZG1S |
| Motherboard Manufacturer | Quanta Computer |
| Project Code | ZG1S |
| Board Number | ZG1 |
| Revision | A3 |
| Date | 2003,5,29 |
| CPU Platform | Micro-FCPGA |
| CPU Model | BANIAS / ODEM |
| PCH / Southbridge | ICH4-M |
| GPU Type | ATI M7/M9 |
| EC / KBC | PC87591 |
| Audio Codec | TI-TPA43AB21 |
| BIOS / SPI Flash | FLASH |
| Charging IC | MICREL 280 |
| RAM Type | DDR SDRAM |
| RAM Architecture | DDR-SODIMM |
| LAN IC | 4401/5702 |
| WiFi / WLAN IC | Mini-PCI |
| Card Reader IC | O2 OZ711M1 |
| USB Hub IC | CK408 |
| Thermal Sensor | CPU Thermal Sensor |
