Schematic Acer Predator Triton 300 SE PT314-52s Quanta ZGN Rev A1A Schematic
BrandQuanta Computer Inc.
Project CodeZGN
Document NumberZGN Block Diagram
RevisionA1A
DateMonday, March 21, 2022
CPU PlatformAlder Lake-P
PCH / SouthbridgeAlder Lake-PCH
GPU Typemax-p/"]NVIDIA GN20-E3 Max-P[/URL] / GN20-E5/E6/E7 Max-Q / GN20-P1 Max-P
Graphics ArchitecturegDDR6
RAM TypeDDR5 4800MHz
RAM ArchitectureChannel A / Channel B
RAM Quantity / Slots2 x SODIMM
EC / KBCIT5570
Audio CodecALC3324
LAN ICE3100G
WiFi / WLAN ICCNVi / Discrete
HDMI Level ShifterPI3HDX12211ZHEX
Card Reader ICSD7.0 / SD3.0
USB Hub ICPS8811 QFN36 GTR2-A3
Charging ICCCG6 CYPD6127-48LQXI
Power IC(s)SLGC55544CVTR
Thermal SensorG-Sensor (D5/D7)
The Quanta ZGN project is an Alder Lake-P platform paired with an Alder Lake-PCH, supporting up to 32GB per SODIMM of DDR5 4800MHz memory across two channels. Graphics are handled by NVIDIA GN20-E3 Max-P, GN20-E5/E6/E7 Max-Q, or GN20-P1 Max-P with gDDR6 VRAM. The embedded controller is an IT5570, and audio is provided by an ALC3324 codec. Networking includes an E3100G LAN IC and CNVi/discrete WLAN. The system features a PI3HDX12211ZHEX HDMI re-driver, PS8811 USB hub ICs, and a CCG6 CYPD6127-48LQXI charging/PD controller. Storage supports PCIe Gen4 x4 SSDs via M.2 2280 slots. The block diagram is dated March 21, 2022, revision A1A.
A: The embedded controller is an IT5570.
A: The board supports DDR5 4800MHz across two SODIMM slots, configured as Channel A and Channel B, with a maximum of 32GB per slot.
Q: What charging/PD controller is used?
A: The charging and USB-C PD controller is a CCG6 CYPD6127-48LQXI.
Q: What audio codec is present?
A: The audio codec is an ALC3324.
  • Acer Predator Triton 300 SE PT314-52s Quanta ZGN Rev A1A Schematic.pdf
