acer predator 17 x pegatron viper2 p7rcr
The Pegatron Viper2 motherboard is a KabyLake-H platform designed for high-performance notebooks, featuring an Intel SKYLAKE_HALO BGA1440 processor and an Intel KBL PCH-H chipset. Graphics are handled by a discrete NVIDIA N17E-G3 GPU with 8GB GDDR5X memory. The system firmware is stored on a 16MB MX25L12873FM2I-10G SPI flash, with an additional W25Q80EWSNIG flash for the ITE IT8987E/BX embedded controller. Memory configuration consists of two DDR4 2400MHz SO-DIMM slots supporting up to 64GB. Audio is provided by a Realtek ALC255 codec paired with an ALC1001 amplifier. Connectivity includes an Intel E2500 LAN controller, Realtek RTL8723BE wireless module, and multiple USB 3.0 ports managed by PS8713B redrivers. The charging subsystem is built around a BQ24735RGRR charge IC, while the HDMI interface uses a PI3DPX1203ZHEX level shifter.
A: The primary BIOS flash is a 16MB MX25L12873FM2I-10G SPI ROM.
| Brand | Pegatron |
| Model | Viper2 |
| Motherboard Manufacturer | Pegatron Corp. |
| Project Code | Viper2 |
| Revision | R1.0 |
| Date | Monday, October 17, 2016 |
| CPU Platform | KabyLake-H |
| CPU Model | SKYLAKE_HALO BGA1440 U0300 DCL8066202194730 |
| CPU Socket | BGA1440 |
| PCH / Southbridge | INTEL KBL PCH-H |
| GPU Type | NVIDIA N17E-G3 |
| Graphics Architecture | NVIDIA 837 Pin 23mm X 23mm TDP 2.8W |
| dGPU Chip Number | N17E-G3 |
| EC / KBC | ITE IT8987E/BX |
| EC/KBC Package | SMBus |
| Audio Codec | REALTEK ALC255 |
| BIOS / SPI Flash | MX25L12873FM2I-10G |
| BIOS Flash Exact Model | MX25L12873FM2I-10G |
| BIOS Flash Capacity | 16MB |
| Compatible BIOS IC Models | W25Q80DVSSIG |
| EC Flash / ROM | W25Q80EWSNIG |
| Charging IC | BQ24735RGRR |
| Charger Architecture | SMBUS1(EC) |
| Power IC(s) | G781P8 |
| RAM Type | DDR4 2400MHz |
| Card Reader IC | RTS5306E |
| USB Hub IC | PS8713B |
| LAN IC | LAN E2500 |
| WiFi / WLAN IC | RTL8723BE |
| HDMI Level Shifter | PI3DPX1203ZHEX |
VIPER2
Kaby Lake-H
N17E-G3
N17E - G3
IT8987E/BX
ALC255
MX25L12873FM2I-10G
W25Q80DVSSIG
W25Q80EWSNIG
BQ24735RGRR
G781P8
RTS5306E
PS8713B
LAN E2500
RTL8723BE
PI3DPX1203ZHEX
VIPER2
Kaby Lake-H
N17E-G3
N17E - G3
IT8987E/BX
ALC255
MX25L12873FM2I-10G
W25Q80DVSSIG
W25Q80EWSNIG
BQ24735RGRR
G781P8
RTS5306E
PS8713B
LAN E2500
RTL8723BE
PI3DPX1203ZHEX
