acer ferrari 5000 quanta_zc3_revb2a schematic
acer ferrari 5000=1=quanta_zc3_revb2a.pdf
The Quanta ZC3 project, revision B2A, is an AMD K8/RX485/SB460 platform motherboard dated June 8, 2006. It supports an AMD Turion 64 processor via a 638 S1g1 socket, with graphics handled by an ATI M56-P GPU featuring four GDDR3 500MHz VRAM chips. System memory consists of two DDR II-SODIMM slots supporting DDR II 533/667MHz. The embedded controller and Super I/O functions are managed by a PC87383. Audio is provided by an ALC883 codec, and networking by a Broadcom BCM5788MG Gigabit LAN controller. The BIOS flash supports second-source options from Atmel or SST. Power management includes a MAX1999 charging IC and a MAX8774 CPU core regulator. A TI 7412 card reader controller and an ICS951462 clock generator complete the core chipset configuration.
A: The schematic indicates BIOS flash options from Atmel or SST, referenced as UC@ ->(ATMEL,SST).
A: The embedded controller and Super I/O are handled by a PC87383.
Q: What is the charging architecture on this motherboard?
A: The charging IC is a MAX1999, with CPU core power managed by a MAX8774.
Q: What memory configuration does this motherboard support?
A: It supports two DDR II-SODIMM slots with DDR II 533/667MHz memory.
| Project Code | ZC3 |
| Revision | B2A |
| Date | Thursday, June 08, 2006 |
| CPU Platform | AMD K8/RX485/SB460 |
| CPU Model | AMD Turion 64 |
| CPU Socket | 638 S1g1 socket |
| Northbridge | RX485 |
| Southbridge | SB460 |
| GPU Type | ATI M56-P |
| Graphics Architecture | VRAM X4 (GDDR3 500MHZ) |
| EC / KBC | PC87383 |
| Audio Codec | ALC883 |
| BIOS / SPI Flash | UC@ ->(ATMEL,SST) |
| RAM Type | DDR II |
| RAM Architecture | DDR II 533,667MHz |
| RAM Quantity / Slots | DDR II-SODIMM1, DDR II-SODIMM2 |
| LAN IC | Broadcom BCM5788MG Giga LAN |
| Charging IC | MAX1999 |
| Power IC(s) | CPU CORE (MAX8774) |
| Card Reader IC | TI 7412 |
| Clock Generator | ICS951462 |
| Super I/O | PC87383 |
| SPK AMP | HP AMP |
| Thermal Sensor | CPU THERMAL SENSOR |
ZC3
K8
RX485
SB460
AMD Turion 64
638 S1G1
RX485
Northbridge / MCH
SB460
M56-P
PC87383
ALC883
BCM5788MG GIGA LAN
MAX1999
7412
ICS951462
PC87383
Super I/O
ZC3
K8
RX485
SB460
AMD Turion 64
638 S1G1
RX485
Northbridge / MCH
SB460
M56-P
PC87383
ALC883
BCM5788MG GIGA LAN
MAX1999
7412
ICS951462
PC87383
Super I/O
