acer aspire es1-331 wistron fauchon 13 14259-1
The Wistron Fauchon-BDW 13"SA motherboard, project code 4PD045010001 and PCB P/N 14259 revision SA, is built around the Intel Broadwell-U 15W CPU platform with integrated UMA graphics. Memory architecture consists of two DDR3L-1600 SO-DIMM slots. The system uses an SPI flash for BIOS storage and is managed by an Infineon KB9028Q EC/KBC. Charging is handled by a BQ24735 charger IC with DCBATOUT architecture. Power regulation includes TPS51225RUKR-GP, TPS51624RSMR, TPS51716RUKR, SY8208DQNC, RT8068AZQW, RT8179CGQW, and RT8120CGQW. Audio is provided by a Realtek ALC3227-CG codec. Networking includes a Realtek RTL8107ESH-CG-GP 10/100 LAN controller and a Realtek RTL8111HSH-CG 10/100/1000 LAN controller, with NGFF WLAN + BT support. A Parade PS8407A HDMI redriver is used for HDMI 1.4a output. The card reader is a Realtek RTS5237S-GR, and a STSTM32F102CBT6 sensor hub is present. Thermal monitoring is handled by an NCT7718W fan controller.
A: The board number is 14259, and the project code is 4PD045010001.
A: The EC/KBC is an Infineon KB9028Q.
Q: What is the charging architecture and charger IC?
A: The charging architecture is DCBATOUT, using a BQ24735 charger IC.
| Brand | Wistron |
| Model | Fauchon-BDW 13"SA |
| Project Code | 4PD045010001 |
| Board Number | 14259 |
| Revision | SA |
| Date | Saturday, September 13, 2014 |
| Document Number | A41102 |
| CPU Platform | Broadwell-U 15W |
| EC / KBC | KB9028Q |
| Audio Codec | ALC3227-CG |
| Charging IC | BQ24735 |
| Charger Architecture | DCBATOUT |
| Power IC(s) | TPS51225RUKR-GP, TPS51624RSMR, TPS51716RUKR, SY8208DQNC, RT8068AZQW, RT8179CGQW, RT8120CGQW |
| RAM Type | DDR3L-1600 |
| RAM Architecture | 2x SO-DIMM |
| Card Reader IC | RTS5237S-GR |
| LAN IC | RTL8107ESH-CG-GP (10/100), RTL8111HSH-CG (10/100/1000) |
| WiFi / WLAN IC | NGFF WLAN + BT |
| HDMI Level Shifter | PS8407A |
| GPU Type | Integrated (UMA) |
| dGPU to UMA Conversion Support | UMA only |
| Thermal Sensor | NCT7718W |
| USB Hub IC | STSTM32F102CBT6 |
4PD045010001
14259
Broadwell-U
KB9028Q
ALC3227-CG
BQ24735
RT8068AZQW
RT8120CGQW
RT8179CGQW
SY8208DQNC
TPS51225RUKR-GP
TPS51624RSMR
TPS51716RUKR
DDR3L
RTS5237S-GR
RTL8107ESH-CG-GP
RTL8111HSH-CG
PS8407A
UMA
NCT7718W
STSTM32F102CBT6
4PD045010001
14259
Broadwell-U
KB9028Q
ALC3227-CG
BQ24735
RT8068AZQW
RT8120CGQW
RT8179CGQW
SY8208DQNC
TPS51225RUKR-GP
TPS51624RSMR
TPS51716RUKR
DDR3L
RTS5237S-GR
RTL8107ESH-CG-GP
RTL8111HSH-CG
PS8407A
UMA
NCT7718W
STSTM32F102CBT6
