acer aspire e5-573g da0zrtmb6d0_quanta zrta_gddr3_bdw_ult schematic
acer aspire e5-573g=1=da0zrtmb6d0_quanta zrta_gddr3_bdw_ult.pdf
This Quanta ZRT/ZRTA motherboard schematic, dated February 11, 2015, documents a Brodwell ULT 15W platform with an integrated PCH. The system utilizes dual-channel DDR3L-SODIMM memory and features discrete graphics options including the N16S-GT and N16V-GM with GDDR3 memory. The embedded controller is an IT8987, with an ITE6515 serving as the EC flash/ROM. The BIOS is stored on an 8M SPI ROM. Power management is handled by a BQ24737RGR battery charger and multiple voltage regulators including the TPS54318RTER, TPS51211DSCR, TPS51216RUKR, TPS51624RSM, TPS51225RUKR, and UP1658RQKF. The audio codec is an ALC255, the LAN controller is a Realtek RTL8111H, and the card reader is controlled by an RTS5170.
A: The embedded controller is an IT8987, with an ITE6515 used as the EC flash/ROM.
A: The BIOS is stored on an 8M SPI ROM.
Q: What is the charging IC used on this motherboard?
A: The battery charger IC is a BQ24737RGR.
Q: What are the discrete GPU options for this platform?
A: The schematic supports N16S-GT and N16V-GM discrete graphics with GDDR3 memory.
| Project Code | ZRT/ZRTA |
| Document Number | 3A144 |
| Date | Wednesday, February 11, 2015 |
| CPU Platform | BRODWELL ULT 15W |
| PCH / Southbridge | Integrated PCH |
| GPU Type | N16S-GT / N16V-GM |
| Graphics Architecture | GDDR3 |
| EC / KBC | IT8987 |
| Audio Codec | ALC255 |
| BIOS / SPI Flash | 8M SPI ROM |
| Charging IC | BQ24737RGR |
| Power IC(s) | TPS54318RTER, TPS51211DSCR, TPS51216RUKR, TPS51624RSM, TPS51225RUKR, UP1658RQKF |
| RAM Type | DDR3L-SODIMM |
| RAM Architecture | Dual Channel DDR III |
| LAN IC | RTL8111H |
| Card Reader IC | RTS5170 |
| EC Flash / ROM | ITE6515 |
Brodwell ULT
N16S-GT
N16V-GM
gDDR3
IT8987
ALC255
BQ24737RGR
TPS51211DSCR
TPS51216RUKR
TPS51225RUKR
TPS51624RSM
TPS54318RTER
UP1658RQKF
DDR3L
RTL8111H
RTS5170
IT6515
Brodwell ULT
N16S-GT
N16V-GM
gDDR3
IT8987
ALC255
BQ24737RGR
TPS51211DSCR
TPS51216RUKR
TPS51225RUKR
TPS51624RSM
TPS54318RTER
UP1658RQKF
DDR3L
RTL8111H
RTS5170
IT6515
