Schematic Acer Aspire E5-411G Quanta ZQMB DAZQMBMB6B0 Rev A1A Schematic
BrandQuanta
ModelEA41_BM (14")
Motherboard ManufacturerQuanta Computer Inc.
Project CodeZQMB421
Document NumberZQMB421
RevisionA1A
DateFriday, June 13, 2014
CPU PlatformIntel Bay Trail-M
GPU TypeN15V-GM ([URL="https://dr-bios.com/components/graphics-models/geforce-820m/"]GeForce 820M)[/URL]
EC / KBCNPCE985LB1
EC/KBC PackageLQFP128
Audio CodecALC283
BIOS / SPI Flash1.8V BIOS + TXE SPI ROM (64Mb)
EC Flash / ROM3.3V EC code SPI ROM (1Mb)
RAM TypeDDR3L
RAM ArchitectureSO-DIMM 0
RAM Quantity / SlotsMaximum 8GB
Card Reader ICGL834L
LAN ICRTL 8111 GS-CG
WiFi / WLAN ICWLAN / BT Combo Half Mini Card
The Quanta EA41_BM (14") motherboard, project code ZQMB421 revision A1A dated June 13, 2014, is built on the Intel Bay Trail-M platform. Graphics processing is handled by an N15V-GM (GeForce 820M) GPU. System management is controlled by an NPCE985LB1 embedded controller in an LQFP128 package. Audio is provided by an ALC283 codec. The main BIOS is a 1.8V BIOS + TXE SPI ROM with 64Mb capacity, while the EC firmware resides on a separate 3.3V EC code SPI ROM of 1Mb. Memory support includes DDR3L via a single SO-DIMM slot with a maximum capacity of 8GB. Peripheral connectivity includes a GL834L card reader IC and an RTL 8111 GS-CG LAN controller. Wireless connectivity is supported via a WLAN / BT Combo Half Mini Card.
Q: What BIOS IC configuration is used on this motherboard?
A: The motherboard uses a 1.8V BIOS + TXE SPI ROM with a capacity of 64Mb.
Q: What EC/KBC chip is used and is it programmable?
A: The embedded controller is an NPCE985LB1 in an LQFP128 package. The EC firmware is stored on a separate 3.3V EC code SPI ROM of 1Mb.
A: The motherboard supports DDR3L memory via a single SO-DIMM slot with a maximum capacity of 8GB.
  • Acer Aspire E5-411G Quanta ZQMB DAZQMBMB6B0 Rev A1A Schematic.pdf
